Honda signature accessories fabric mid panel
AndyC
AndyC
34
88
USA
Just picked up a Honda signature accessories fabric mid panel with the vinyl window for my 1000-5 and was curious what I should use to clean the dust and dirt off the clear vinyl window that won’t scratch it up or make it cloudy?
Reactions: ChadD and TxDoc
Russ989
Russ989
22,642
147,257
I use a few drops of dish soap and warm water.
Stateboy
Stateboy
299
1,740
Wolverine, MI
I'd add to @Russ989 that you should rinse as much of the dirt off as possible before washing to prevent it (dirt) from becoming a grit you rub against the vinyl. I'd use a natural sponge or a microfiber towel with the soap.
Sent from my SM-N960U using Tapatalk
HBarlow
HBarlow
1,626
6,045
Daniels, WV
I agree with the advice above. The manufacturers guidance I've seen prohibits use of glass cleaner such as Windex. Soft cloth, mild soap, and water is recommended.
Reactions: ChadD and AndyC
AndyC
AndyC
34
88
USA
All right just wanted to make sure so I didn’t do something to ruin it, thanks all!
Reactions: ChadD
rickoshea
i use the same mixture that i use on my windshield.a couple drops of dish soap and water in a squirt bottle.it also helps to lube up the zippers when they are caked in dirt and i want to unzip out on the trail.
Reactions: ChadD
Smoking Joe
Smoking Joe
134
418
Alaska
How well does it seal up? Went moose hunting last weekend in my buddy's 1000 and every water hole we hit fogged the windsheild!
Reactions: Russ989 and ChadD
Russ989
Russ989
22,642
147,257
They seal up pretty good, I have the soft doors as well. Nothing to write home about but better than nothing.
rickoshea
you definitely don't want it sealed up of you're hitting water holes. you want it unzipped and rolled up.
Reactions: Smoking Joe
bumperm
bumperm
1,899
6,778
Gardnerville, NV
What Stateboy said.
To add a bit to the cleaning instructions, from one who has cleaned a few $10K glider canopies, it is always best to flush the surface with water first to wash off loose dirt and grit. Never use a dry cloth (even if it's microfiber) on a dry surface.
Reactions: Stateboy
