Confirmed, The Honda Talon transmission gearing is the same as the Pioneer 1000. Almost!
So why is the Honda Talon expected to run 73+ mph while the Pioneer is stuck at 66?
HONDA... that's why.
Many who have pushed the top speed on a Pioneer 1000 knows there is more to be had. But the computer shuts it off at 66.
Ironically that's gear 6, 66 mph!
REAR DIFFERENTIAL
The rear diff gearing changes from 3.375 to 3.307 in the Talon. This with a speed tolerance increase and larger tires helps drive the Honda Talon above 70 MPH stock.
Can this be upgraded for the Pioneer? Most likely no.
It would require a reprogramming and differential gears are not swappable.
REVERSE.
Honda says
Can this be upgraded for the Pioneer? WE THINK SO!
But it is still too early to know for sure. It would come down to if there are any case improvements and if not, then its as simple as changing 2 gears in the sub-transmission and that should do the trick!
Gearing set for the Pioneer 1000 / Talon 1000 with changes noted.
Primary - 1.883
Front diff - 3.384
Rear diff - 3.375 / 3.307 Talon
1st - 2.764
2nd - 2.047
3rd - 1.583
4th - 1.230
5th - 0.968
6th - 0.800
Low - 2.666
High - 1.880
Reverse - 2.222 / 2.640 Talon
REAR DIFFERENTIAL
REVERSE.
Honda says
The reverse gear changes from 2.222 in the Pioneer to 2.640 in the Talon. This provides for lower gearing for "tight situations". One that was highly needed and wanted by many Pioneer owners!Even the reverse gear has been optimized for Sport use for easily exiting from tight situations.
Primary - 1.883
Front diff - 3.384
1st - 2.764
2nd - 2.047
3rd - 1.583
4th - 1.230
5th - 0.968
6th - 0.800
Low - 2.666
High - 1.880
