P1000 How to get more HP out of my Pioneer 1K?
Eddy R
Eddy R
Alberta
Hey, just wondering what options there are to squeeze some more power out of my Pioneer 1000 without sacrificing reliability. I’ve thought about doing an exhaust, but from what I’ve read online, all that’ll do is increase the volume and maybe get you 1 more hp.
Is a putting a tune on it the only option? I know the Talon is making over 100hp with the same engine. Dose anyone know if there’s different parts on the Talon engine to make the extra power. Or is it just how it’s tuned?
Thanks in advance,
Eddy
Fatsquatch
Fatsquatch
Approved Member
121,532
1,013,125
Hidden
Thanks in advance,
Eddy
Talon has different parts in the case.
Reactions: CID and Red500
ODAMO
ODAMO
1,398
3,673
Ohio
Thanks in advance,
Eddy
Why do you want it faster? If it’s to be faster than your buddy who has one of the rubber band units don’t bother. Honda Pioneer1000 will outlast most other brands by a large margin. The more you do to make it faster the quicker it will break. And then you’ll become just as good a mechanic as they are.
Power aside, the experience you feel having an auto shifted manual DCT tranny is like no other.
Belt drive units have to hang their hat on something so they throw high hp numbers at em to get attention. What they don’t tell you about is the high maintenance.
Or just throw a turbo on it…….
5,756
26,436
Not trying to be a smart azz but if you don't need the utility of the Pioneer, use that money to upgrade to a Talon. The Pioneer's suspension is about maxed out with the stock HP. There are several differences between the Pioneer and the Talon's engine, the cam for instance.
Eddy R
Eddy R
Alberta
I’m not trying to compete with a buddy or anyone else. I guess what I’m really after is a bit more torque and acceleration. Just for my own enjoyment and how I like to drive. I don’t need anymore top speed.
I do most my riding in the mountains, so I do a lot of massively steep and long hills, and if it’s not hills I’m tackling it’s heavy greasy mud. I also carry quite a bit of gear in the back and sometimes I’ll have a few passengers with me. I certainly manage get wherever I want to go. But I’d also enjoy a bit more get up and go.
Turbo is out of the question, I don’t need that kind of headache.
Reactions: CID
Eddy R
Eddy R
Alberta
I’ve thought about doing that, but I’m not sure I want to lose the ability to carry more than one passenger and all the gear I bring with me. I also have no interest in a 4 door talon. Too much money, and a lot of trails I run are pretty tight. So having a tight turning radius is a must.
Reactions: CID
DRZRon1
DRZRon1
1,451
4,432
PA
Options
Drop a talon engine/ecu/etc in
If u have larger tires - go back to stock - nothing robs HP more than larger tires and wheels
Get your friends zepbound shots
Not sure what u carry -but I am amazed at how many packouts and stuff people carry - like 5x the amount a KOH race car team carries - hundreds of pounds and enough stuff to rebuild the entire car including the engine
There is not much u can do to squeeze more bolt on power other than a tune
Anything above that you must go inside the belly of the engine
Good luck
bumperm
bumperm
1,931
6,829
Gardnerville, NV
Dunno, maybe I'm just easy to please. My drivetrain is stock, and it's never had me wanting more power or performance.
Eddy R
Eddy R
Alberta
It’s pretty easy to fill the back with gear. I always have a rifle and targets, all my recovery gear (saved my ass more than once, and other people I run into who are stuck and unprepared), I’ll bring a few fold out stools, stuff to build a fire or clear blocked trails, first aid kit, and a cooler. It’s not hard to add weight. All that stuff is what I’d consider essential to go out into the deep woods.
When I go out I don’t wheel with a group. Just me and whoever I bring along for the ride. So I like to be prepared.
It was mostly a question of curiosity. Like I said, I manage to get wherever I want to go as it is. Was just wondering if there’s some simple options to get a bit more out of it.
So has anyone here done a tune on their pioneer? Was it noticeable? Worth it?
Reactions: futzin
