International DT466
gauspohl4305
gauspohl4305
27
58
Kentucky
Looking for some people that have some knowledge and preferably 1st hand experience on the Internationals DT466 or others for a tow pig. Looking for input on cruising speeds with what weights, what to look for as far as year or truck, what kind of tranny is best, what's a good price,or any other details that can be provided.
popeye
popeye
3,275
14,644
kapowsin, Wa
Have rebuilt, new cylinder liners, pistons, rod bearings, “the works kit” that international sells for them, pretty darn tough little engines. Stay clear of the last few years they made them. Like 02-06 ish I think, they had many more issues, the same fuel system as the notorious 6.0 ford, prone to high pressure oil leaks on the manifold feeding the injectors, sensitive and finicky injection system, egr valve and cooler issues. The generation befor that was bullet proof. Just check and see what all the tractor pull guys are after
HBarlow
HBarlow
1,627
6,047
Daniels, WV
If my memory hasn't failed, the designation "DT-466" referred to the IH inline six cylinder turbodiesel engine not the truck. It is a common and tough light truck engine that was installed in thousands of IH trucks.
To determine value you need to know the year, equipment, mileage, and condition of the particular truck. Cruise speed depends entirely on how a particular truck was "spec'd" meaning what transmission, differential gears, and size of tires/wheels the truck has.
Reactions: ChadD
gauspohl4305
gauspohl4305
27
58
Kentucky
Any knowledge on old ambulance's? Not the 1 ton van style? Any recommendations on what the start looking for? Looking to pull approximately 10k lbs, and be able to cruise 70 mph or so.
HBarlow
HBarlow
1,627
6,047
Daniels, WV
I'm an old RVer and had a lot of experience with RV towing with light trucks. I bought my first travel trailer in Bremerton, WA in 1972 and was an avid RVer until a year ago. That's more than 40 years.
I sold my last Dodge-Cummins to friends back in Texas a year ago but owned them for years and put hundreds of thousands of miles on them. My vision is fading and I'm not safe to pull or back trailers any longer so was forced to give it up. Sadly!
I was also an RV transporter leased to three different RV Transport companies from 2005 - 2007. I pulled new trailers from factories to dealers in all 48 contiguous states and many Canadian provinces.
I also had a late close friend who was a long-time truck salesman, sales manager, and dealer and learned a lot from him.
I'll tell you my honest opinions. You already have your mind made up and you won't like my answers but you will eventually learn that I was correct.
1. You don't want an old high mileage medium duty truck like an IH DT466. They'll beat your kidneys out and empty your wallet and bank account. You want to tow with a diesel-powered Class III ("one ton."
2. Towing 10k is nothing for a modern diesel light truck.
I'm willing to answer all your questions if you want to learn but I'm not willing to argue with you about my recommendations.
