HondaTech
The 520 has new A arms, shocks, computer, etc. 1st and 2nd gears and both difs have a different part number. The ring and pinion gears are the same. The crankshaft is the same and both the quads Foreman and rancher also use the same crankshaft. I have some wonderful 50 inch trails so I'm buying one in April. The tires are way better plus I still have my 30 inch tires, wheels, and spacers for installing the 30's. With the 30's top speed was 46 mph and it would pull 5th gear on long mild up hills.
Roll Cage also different as well.
Appears the front diff is only a new number because of the pinion nose needle bearing, its a P520 specific part number.
