Kawasaki Teryx 14" Wheels Fit a Talon X?
Nevada Notch
Nevada Notch
Carson City
Will the following 2019 Kawasaki wheels fit the 2021 Talon X? I am aware they are the same bolt pattern but was wondering any interference issues such as brakes or offset.
Front is 27x9.00 R14
Rear 27x11. R14
115,818
Don't need it for ground clearance.
Found a good deal on Teryx wheels and also found some 28x14 front sand and 28x14rear paddle tires. I don't want to go with a larger tire for dune climbing reasons.
So if there paddle tires, then there Aftermarket anyways and Im assuming the rims are also?
id be very Leary of the smaller rim size and not knowing the offset with your brakes For rubbing. You need to physically try them to see if you can. For one, your gona be hard pressed to know your question on here being its from a TERYX.
In other words, quit messin around and just buy the correct ones for your machine so u don't have to guess.
to add to this, the answer is Negative! The Talon needs 15” wheels to clear the calipers
Sheetmetalfab
Sheetmetalfab
2,227
14,035
Alaska
I’m running 14’s with no issues.
System 3 6-1 offset front 4-3 rear.
906UP
906UP
14,405
136,887
da Yoop
It's hit-n-miss on whether 14's clear, some do, some don't. It depends on the offset and how thick the wheel is.
115,818
Id stick with 15”s IMO. Ive had them on my pioneer since christ was a corporal and won't look back. Takes the worry out and the leas tightness helps for less mud caking. But if the shoe fits ware it lol
Sheetmetalfab
Sheetmetalfab
2,227
14,035
Alaska
Op said talon X.
I’m not aware of any aluminum 14’s that don’t fit.
I know the talon R rubs on some.
(Fixed by 45 seconds with a grinder)
Reactions: Blownzuki
