P1000 KFI plow mount dimension questions
Springer
Springer
312
234
Hi all. Can anyone tell me what the distance is between the mounting tabs on the push tubes of a KFI, or Denali system?
I currently have an Eagle plow system transferred over from my 700, but the new Eagle mount for the 1000 hangs down like 4+ inches, and requires that I remove 8 bolts to get my ground clearance back for trail riding.
I am hoping I can find a mount that is similar to the 700 mount. That worked real well. If the KFI or Denali push tube tabs are the same distance apart they should work.
Thanks
Springer
Springer
312
234
Well, have not heard from any KFI plow owners so I went ahead and ordered a mount from them. Should have it in few days and will know my answer.
Thanks!
solrus
solrus
1,629
2,511
Montana
I have KFI on p500, no ground clearance problems. Push tube tabs positioned in front and not under . So I keep plate all year around, it's part of my skid protection plate system.
Sent from my XT1585 using Tapatalk
solrus
solrus
1,629
2,511
Montana
Look my build pics
