P1000 Le tire size how big can I go
rodmor
Wv
I have a 01 le I would like to go with 30 inch tires no lift but I’m thinking I’ll be limited to 28s dose anyone know how much I can do
BE6027E5 7F4D 4D3D 85AF AAF078078D6B
Dirtstiffs-1000
Dirtstiffs-1000
1,554
5,651
hondasxs.com
Use the search engine. Tons of threads about tires.
I run 29" Maxis Bighorns on my LE, although being an LE makes no difference as OEM clearance and offset dimensions are common to all 1000 5's.
Taller and wider than about a 29" x11 x 14 and you likely need lift and perhaps wheel spacers.
JMO, do a search.
Nice ride by the way.
G
GWH
748
2,475
Las Vegas Nevads
JMO, do a search.
29 bighorns 2.0 on my 2016 deluxe 5.best improvement,other than Elka ft shocks.
265,332
I have a 01 le I would like to go with 30 inch tires no lift but I’m thinking I’ll be limited to 28s dose anyone know how much I can do View attachment 234107
I have about 6000 miles on my LE. Largest tire you can run without lift and spacers is 28x10x14 tires. Any larger they will definitely rub off road especially when turning left due to lower clearance because of footwell around brake pedal compared to passenger side.
sporter
44
Rodmor - What's the story on that paint?
dook
65
160
montana
I have 30x10R14 on my P1K3, same size all around. The front tires do rub the back of the fenderwell on sharp turns, which only happens at low speed. It makes a lot of noise when it does, but hasn't harmed the fenderwells yet. Been that way 1500 miles or so. The tires are 8 ply Kenda Mastidons DOT and I run 9 PSI in them, the ride is very smooth. If I had 28" tires on those 14x8 rims, they would be kinda low profile and I think the ride would suffer significantly.
Pioneer 003
Reactions: rodmor
Amre2me2
Amre2me2
381
1,423
Colorado
Remember, you loose a lot of power with larger tires. My buddy put 29s on his LE and hates them. He can’t make it up some of the rougher trails that I can with my 27s. I live at 8500’ and we ride at 8000-14000’.
