P1000 Led bar, 4 pin relay, 4pin switch
W
WVMatthews1982
21
36
WV
Oh my Lord... does anyone have a wiring diagram for an led bar using a 4 pin relay, and a 4 pin switch? I am about to pull my hair out. Thought I had it right but its not working at all. I can jump power straight to the light and it works. Not sure if i have a bad relay or switch, or if I'm just and idiot and have it wired ass backwards.
Reactions: Lady01
Seadonist
Seadonist
380
1,117
New Orleans
Cbc60282bf6b5634f6e84a989389549c
Reactions: Lady01
W
WVMatthews1982
21
36
WV
I'm assuming underhood dist block is a fuse box? If so what is A? And also the pin orientation of the switch is different. 2 pins on hot side 2 pins on ground.
Screenshot 2020 09 30OnlinePromotionalGraphicsVideoEditor fed40afa da27 41ab 9137 9fdadb31fc7b
Reactions: Lady01
W
WVMatthews1982
21
36
WV
There are many different configurations of switches.
You need to post which one you have.
Need a link and or wire diagram.
Had to edit to add a pic and provided switch diagram. Guess I dont understand how it ties back into the relay.
Reactions: Lady01 and Hondasxs
68,143
The "to radio, lights, ect." is the line going to the relay.
The yellow line in that wire diagram.
Reactions: Lady01
W
WVMatthews1982
21
36
WV
Finally got it thanks a bunch fellas.
Reactions: Lady01
