Lets Talk Grounding... Especially for the WINCH!
66,871
Lets talk winch grounding for your winch.
First, I am no expert. I am self taught in regards to 12v systems. Over the past few years I have learned so much about 12v systems and I hate seeing so many people wire up their machines and have issues, sometimes repeated issues, of dead batteries.
Here I will give 3 examples of where to pick a winch ground location.
FYI, you should NEVER run a winch through a bus bar. Not many can truly handle 200+amps, plus that adds another level of complexity we don't need.
Ok...
Lets review this and talk.
I'm not saying its perfect. but I would like to hear what you have to think.
FIRST - The factory installed winch, single battery.
Here the best choice is to use the extra provided ground wire (blue tape wire). Doing this routs power through the frame and allows pulling a little power from the stator on the way, thus slightly reducing the load on the battery. This is also Honda's recommend method.
Single
SECOND - Winch with a dual battery system. NOT IDEAL!
Here we have used the factory provided extra ground wire for our winch ground. This is not ideal because the return path pushes through the factory system and could pass thought the primary battery as well.
Our goal with a dual battery system is to protect the primary battery.
In this case, if the isolator cuts off, the ground will still hit the primary and from there I am not exactly sure if it will be considered returned or continue on. If it is considered returned, then I would not expect that battery to last long.
Not ideal
THIRD - The best grounding method.
Here we force the return path to be directly to the second battery. If the isolator cuts off then the primary battery is not effected in any manner.
Best
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I personally used option 3. I think this added the best protection to the Honda wiring system yet good connection for the winch to get the best amp. In this subject we should also talk about wire size. Many people under size the wire to their winch. Under high load the winch pull 200+ Amps. Using the proper size wire or slight larger is as important as grounding to prevent heat build up and damage to the system.
Great discussion.
Sent from my SM-G781V using Tapatalk
906UP
906UP
14,275
135,391
da Yoop
Mine is very similar to #3 too, I have my aux battery mounted in the rear (T1Kx) with cables running to the front, the + from the aux battery, the winch + and aux + from the isolator are on a stinger. The aux -, winch - and factory extra - are connected to another stinger. The main & aux batteries are separated but use the frame as a common ground. The factory extra + goes to the main lug on the isolator to charge the main battery.
Bama-Daniel
Bama-Daniel
795
7,916
Priceville, Alabama
Great explanation. Explanations like this is one of many examples why this club is so awesome. I used the 3rd method too. I wanted all accessories to be on the 2nd battery and don’t want anything pulling from my primary system. Thanks for sharing.
Reactions: Ridinfool and ChadD
Hillbillytnt
Hillbillytnt
550
2,023
Ky
Great info. Mine is #3. I’ve got + and - bus bars, along with a couple things from the club store, just waiting for the weather to break a bit to install. That 2nd battery terminal gets crowded running everything through it to protect primary. Hoping to get it down to big 3 - winch, isolator and stinger. Debating what size wire is best for bus bars. Appreciate all the help and info.
66,871
Yes. Those 3 need to be direct to the battery.
Everything else that needs power can run after the stinger off the fuse box.
If you need constant. Hook it to the battery side of the stinger.
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
This, Ed Zackery 👆👆👆👆
Pilotadam
Pilotadam
326
735
Pell City, Alabama
If you need more battery junctions I used these for mine. Mostly because I mounted a blue tip Optima Battery under the driver seat. Than ran some #1/0 welding cable from the battery to this junction. Then split off to the winch and bus bar.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
For got the picture.9639389cde73894d92eeec325439f86e
Reactions: Bama-Daniel
66,871
For got the picture.View attachment 312667
This is a mini bus bar.
Bus bars have there own issues to discuss when the isolator is also connected to that same bus bar.
Where as, installs I have seen with bus bars. They could completely remove the second battery and everything would still work.
That's far from a proper install for our purposes.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Let me clarify. I have a True isolator between the two batteries. I use these mini bus bar as the battery connection under the hood since my 2nd battery is under the seat.
Robobrainiac
Robobrainiac
2,551
8,962
Good information. I am not crazy savvy on electronics or resistance and I know a little. My winch was direct to the main battery. After I added my auxillary battery the winch was then connected directly to the auxillary battery. Any high amp product should always perform best when connected directly to the power source.
Reactions: ChadD
Scoop
Scoop
5,144
20,336
  3. Talon R LV
You can find them.
For the winch connections, I only use a bus bar for the negative side and the ground cable that goes from that bus bar back to the AUX battery negative is on the same post on the bus bar as the winch ground. My winch positive goes directly to the positive post on the AUX battery. Isolator is not connected to any bus bars - only to the two batteries.
Rated for 250A @ 12VDC:
Screenshot 20220110 000114 Amazon Shopping
