Lift Kits??
N
NorthernHonda
Grande Praire, Alberta, Canada
Hey All, I have a 2019 P1000-5. My front driver side shock is leaking, so I have two questions.
#1.Aftermarket suspension, Elka, Fox , Evan Walker....which one would you guys suggest.
#2. Lift Kits...I'm thinking about a Highlifter 2.5" or something comparable. Has anyone had any issues with excessive wear on front end or rear end parts that they could attribute to a lift? Has your lift been worth it?
Thanks in advance!!
Reactions: JenElio
JenElio
JenElio
73,305
667,006
Loxahatchee, florida
Thanks in advance!!
Well......first off Welcome to the club!!
Pics or it didn't happen!!!
Shocks are like a lot of things, depends on your riding style. FYI usually aftermarket shocks will allow you some lift by adding some preload. Unfortunately I can't be much help on the subject cause I have yet to upgrade my shocks but im sure some of the guys will chime in soon.
Reactions: Isaiah
DDDonkey
Before I can give you an answer on a lift kit my question is what size tire are you looking at running? You may be able to get by with running some forward and rear a-arms and a bigger tire but keep that nice low center of gravity. Some a-arms even have a 2 to 3 inch lift built-in to them.
