How many amps is your rocker switch rated for?
Just going from memory
I think that lightl bar is 300 watts...300watts÷12 volts= 25 amps
You may need to wire the light directly to the battery, and use a 30 amp relay. The relay is a switch within a switch. When you activate the rocker, it will trigger the relay to send full power from the battery needed to the light. This assumes you have sufficient gauge wire for the current drawn.
If your switch is bordering right on the max current draw, it may very well work fine at the beginning, but fail to be able to maintain correct function with extended times.
One other thing.... Light bars with high current (amp draw) can cause magnetic fields that can interfere with radios and their proper function.
You may need to get them off the same circuit.
