What is the biggest size that will fit on the front bumper of the deluxe model? debating if I want to use stock bumper of buy after market depending on what size light bar will fit, I would like to go 20-32in.
Thanks guys,
Thanks guys,
I put 20 inch. Mines a base model but I thought stock bumper was same on base and deluxe.What is the biggest size that will fit on the front bumper of the deluxe model? debating if I want to use stock bumper of buy after market depending on what size light bar will fit, I would like to go 20-32in.
Thanks guys,
that looks real good can u add some more pics pleaseI put 20 inch. Mines a base model but I thought stock bumper was same on base and deluxe.
some pics on how it mounted and does it stick out in front can u take a side view if u have time thanks I really like this I might have to steel itI put 20 inch. Mines a base model but I thought stock bumper was same on base and deluxe.
1 3/4' Roll Cage Bar Light Whip Mounting Billet Aluminum Clamp Black 1.75' UTVsome pics on how it mounted and does it stick out in front can u take a side view if u have time thanks I really like this I might have to steel it
ok thanks Im not sure this would work for me as I like to run over trees sometimes I might break it. what I am looking for is something that sits recessed in the bumper
real nice can u take some pics next time u have some light so we can see it better thanks a lotI use a little 8 inch opt7 bar with the opt 7 mounts. More than enough light to light up directly in front low where my big bar misses
thanks a lot for taking the time to take the pics looks real good
I noticed that your bar is center mount not bottom I assume u did that cause it wouldn't fit otherwise? Also did u happen to try any bigger ones like a 12 inch?Front view. Lights up the area where the big bar doesnt. Directly in front of the bumper down low
does it have spot and flood or just one or the otherI didn't try anything bigger. A 10 or 12 might might fit. I ordered the mounts with the light and it was gonna be a rear light then I decided to stick it on the bumper. That was the only place the mounts would fit. It lights up well. Sometimes I just roll with that light only
I still can't tell how u have that mounted looks like it is sitting in mid air lol I assume it is mounted from above so it is actually hanging?I put 20 inch. Mines a base model but I thought stock bumper was same on base and deluxe.
