P1000m5 Light Bar on Stock Front Bumper
K
Kyle
What is the biggest size that will fit on the front bumper of the deluxe model? debating if I want to use stock bumper of buy after market depending on what size light bar will fit, I would like to go 20-32in.
Thanks guys,
Calvin
Calvin
42
Benton, La.
Thanks guys,
I put 20 inch. Mines a base model but I thought stock bumper was same on base and deluxe.
Reactions: Itsalljake
K
Kyle
It is the same bumper I was looking at pictures of the pioneer 700 and thought it was the 1000. The 700 had a different bumper than the 1000s
dale5740
dale5740
886
417
mt airy md
some pics on how it mounted and does it stick out in front can u take a side view if u have time thanks I really like this I might have to steel it
dale5740
dale5740
886
417
mt airy md
ok thanks Im not sure this would work for me as I like to run over trees sometimes I might break it. what I am looking for is something that sits recessed in the bumper
Scooterchris
No longer active.
Dec 25, 2015
396
237
I use a little 8 inch opt7 bar with the opt 7 mounts. More than enough light to light up directly in front low where my big bar misses
20160308 231520
Scooterchris
No longer active.
Dec 25, 2015
396
237
Front view. Lights up the area where the big bar doesnt. Directly in front of the bumper down low
20160321 191148
dale5740
dale5740
886
417
mt airy md
thanks a lot for taking the time to take the pics looks real good
dale5740
dale5740
886
417
mt airy md
I noticed that your bar is center mount not bottom I assume u did that cause it wouldn't fit otherwise? Also did u happen to try any bigger ones like a 12 inch?
Scooterchris
No longer active.
Dec 25, 2015
396
237
I didn't try anything bigger. A 10 or 12 might might fit. I ordered the mounts with the light and it was gonna be a rear light then I decided to stick it on the bumper. That was the only place the mounts would fit. It lights up well. Sometimes I just roll with that light only
dale5740
dale5740
886
417
mt airy md
does it have spot and flood or just one or the other
dale5740
dale5740
886
417
mt airy md
I still can't tell how u have that mounted looks like it is sitting in mid air lol I assume it is mounted from above so it is actually hanging?
