Light Rocker Switch
Merv
VIRGINIA
I had the Honda dealer install Honda’s LED light bar on my 2022 Pioneer 1000-5. It operates fine with no issues. The rocker switch that comes with the light bar has no lights and has just two wires (one white, the other white with a black stripe) connecting to the rocker switch. I‘d like to replace it with a 5-pin rocker, but need some guidance on how to treat the two existing wires so it’s compatible with a 5-pin rocker. Thanks.
Reactions: TxDoc and EMAW
66,822
Hi.
So I am assuming it is positive switched.
We need to find out which wire is the source and which is fed.
I will assume white is the source.
I will also assume it's on a key-on circuit and not constant.
So
White to #2 and black to #3.
You can jump #2 to #6 to get lower led.
Ground 7 & 8. C36cb27ad239a7db1a982b32163d974c
Merv
VIRGINIA
Thanks. Let me see if I understand you correctly.
”Black to #3” - Is this my white wire with a thin black line?
”Ground 7 & 8” - Do I jump the two and wire a dedicated ground to my NEG bus bar or other suitable ground?
Given my inexperience, I was sort of guessing I had to run the white to 2,3,6 and the other wire to 8 and 7.
66,822
7 & 8 to any ground, yes jump them together.
2 is the input. White [or black]
3 is the output. Black [or white]
6 is the lower led positive.
3 is the upper led positive.
So when "on" 2 feeds 3. Thus the upper led comes on.
We need to figure out which of your 2 wires is the input. [White or black] Then put them accordingly.
If the input is a key-on source. When you can make a jumper for it over to 6 for the lower led.
J_Rip
J_Rip
70
405
53
Texas
  2. Talon R4 LV
Thanks. How do I determine which of the two wires is input? I have no aptitude for this.
If you have one white and one white with a black stripe, one has to be attached to a battery source and one is going to the light bar. If you don't have a multimeter then you will just have to look at the power source, and what's attached to the light to see where they are coming from.
66,822
Ok...
Do this.
Ground 7 & 8 as mentioned. Don't hook up 2 and 3.
Hook the white to #6. Did the top of switch light up?
Yes, that is the input.
Put it on #2 and black on #3
If No.
Remove white and hook black to #6.
Did the top of the switch light up?
Yes, black is the input.
Put it on #2 and white on #3
If both are no. Then report back.
Do not continue testing.
66,822
I bet the input is the black stripe.
Just realized that's the hot wire used for several other sources.
A
Andrewwallace1956
Pa
I see my headlight switch (35230HL4AQ1) in the parts diagrams
Wishing it was backlit for ez at night
Is the 35330HL4AK1 backlit?
Would it work?
Reactions: TxDoc
Jankyeye
Jankyeye
827
4,003
Tampa, Fl.
Would it work?
Welcome From Fl. I believe this is what your looking for.
