P500 Lights
mdavenpo
Hello all,
I'd like to add a front light bar and rear lights for night launching my small boat on a trailer.
Looking for recommendations of what and where to purchase.
Thanks,
Mark
Bad_bowtie
Bad_bowtie
Huge member
2,480
14,901
East Tennessee
I put an Auxbeam light bar on the front and Auxbeam cubes on the rear on mine a year ago. Very happy with them
0603170813
0623171610 HDR
159,938
I went with Opt 7 brand for pods and light bar, can't say if they're better or worse than anything else out there. Light bar on the roof has taken a beating and still works fine. Came with everything though, relays, inline fuses and toggle switch's.
Front
JCart
JCart
897
2,024
Kamloops, BC Canada.
I installed VisionX 4.5" light cannons on the A pillars looking forward, just above the hood and same brand rear auxilliary light Center of cab facing backwards. All LED and very bright, low amp draw and the Cannons you can change the covers for different needs yellow, blue or pattern, I use clear eurobeam it's like a combo fog and spot light they make durable products. Pix in link P5 lights folder.
Cheers
j
DaddyDubbs
DaddyDubbs
13,936
130,306
I went with a cost effective solution from Tractor Supply that I am quite pleased with...
Traveller 7.25In 36W Camo Light Bar SKU [HASHTAG]#115167399[/HASHTAG]
Mounted above winch on Strong-Made bumper ( only reason I got a camo light was a special sale, about half off)
I used the Traveller 2 in. Adjustable Mount SKU [HASHTAG]#116882599[/HASHTAG] to mount on the bar above winch
Winch1
On the rear I went with the
Traveller 15W Square Worklight SKU [HASHTAG]#116955799[/HASHTAG]
I modified the original front bracket to mount the rear light.
RearLED03 RearLED01 View of rear light at night
I needed to keep everything below the roof line to fit in my enclosed trailer, plus I didn't want lights in danger of being torn off or damaged by branches
rocmar
rocmar
4,741
5,774
4 CORNERS
View attachment 48200 View attachment 48201 View of rear light at night
Camo..light
love it..
cowboyjeff
cowboyjeff
7
12
I put a 22" Light bar on my roofs, they are perfect, some day I would like to add a back up light.
fuimus
fuimus
71
164
WNY
Here is what I did, Cree 4" LED Cubes on back and 3" LED Cubes on ROPS. I have run out of room for Switches.
20170807 064437 20170807 064520 20170808 064352
cowboyjeff
cowboyjeff
7
12
Fuimus those lights are awesome, And I sure do like the green on the pioneer.
Reactions: fuimus
159,938
Reactions: fuimus
JCart
JCart
897
2,024
That's why I went with small basic toggle switches, the P5 just doesn't have enough dash room for a whole lot.
Me as well, simple light "on" toggle switches and mounted mine on the lower dash Dacia towards the power point. This area is a little out of the weather too.... mind you I only have 3 switches so far, forward lights, rear backup light and underseat cooling fan. Put a string of LEDs in clear vinyl tubing and mounted under the dash for in cab lighting, it has its own inline switch.
Pix in link
Reactions: fuimus
Caper
Caper
7,792
11,013
Halifax Nova Scotia
Hello all,
Thanks,
Mark
I got my light at Amazon. 60% off. came with all the harness. I put another switch on, but easy to wire up. but you need the factory harness plug that allows you to just plug the lights, the horn, the winch, and a backup light. The light has 35,000 lumens. cost $60 Canadian. Great light.
Reactions: fuimus
Caper
Caper
7,792
11,013
Halifax Nova Scotia
Mark I also put a 4000 lb warn winch on. I got the mount that is on top. KFI ? , keeps the winch out of most of the water. doesn't affect the temp. This week was 85 or 90 degrees. feeling a lot hotter. temp stayed the same.
IMG 0300
Reactions: fuimus
