Lots of quarters! I take my Pioneer and Talon to a carwash station and knock off the majority. I just use my 3000 PSI pressure washer with the medium and fine tip. Once I have all the dirt off, I use a foam cannon, letting the foam set for 5 minutes between 2-3 foamings, then I put the fine tip (it's just a wider fan pattern) and spray until all soap is gone. That thing is sitting pretty low! 🤣
I don't have to worry about that, so much. Keep mine wrapped in dry cleaning bags. And, in a climate-controlled shop. It's IPA rated at IPA99. True.... But sad
Sent from my motorola edge plus 2023 using Tapatalk
