MUV 700 transmission/ oil pressure problem
Beechwood
Have a 09 Big Red in a Honda shop with low oil pressure that allows the engine to race and not fully engage the transmission. Has around 1100 hrs on it and the oil and filter element were not contaminated with anything when I recently changed out the oil. They have installed a new oil pump and told me this did not help. the shop is about to split the case apart to check the sump pickup and anything else that could be wrong which they estimate at 12 hrs labor. I don't believe this is the only one of these that have done this. If someone else has had this issue serviced I would like to know what was found to have caused it. Thanks if you can share anything on this.
66,870
Can you tell me more about this? What in fact do you mean?
Beechwood said:
allows the engine to race and not fully engage the transmission. .
Do you mean that it revs up when you crank it?
Beechwood
What? The engine revs when the clutch is not engaged, races away from the transmission because the oil pressure drops too low to engage or keep the clutch engaged. I stopped by the shop today, they wanted me to stop in to show me what they found. The pickup sump screen for the transmission was covered with something that prevented/ restricted the flow to the pump. Piston and cylinder had excessive wear probably from the stuff that covered the sump screen, not sure. I collected the substance from the screen but not sure what to do about finding out where it came from or what it is. It was only a small amount of material and everything else in it was clean. I told them to order parts to fix it.
66,870
I asked because I know it want engage if it is at a too high rpm from start. I have experienced this many times on my Rincon while deep water riding. at times when I keep rpm's high and change gears. I have to let off the throttle to get it to engage.
If it had high rpm right at start up, it could be something else as I have had that too.
But I'm glad they found the problem.
cliffrod
Arizona
  1. Big Red
I have a 2010 big red with low oil pressure. I found the pickup screen plugged with clutch material. Did your repair involve replacing the clutch discs?
Reactions: dblizzard
