P1000 My 1000 eps
evildoctor
evildoctor
61
94
NC
Here's my 1000 work in progress. Custom making a roof out of 1/8 in. aluminum (still have to do a few more cuts). Added a 50", 13.5" and a pair of rear LEDs. Also, added a Bazooka brand speakers with build-in LEDs. All controlled with a system call "Switch Pro" if you havn't seen or heard of it, it's worth checking out. I've posted something in regards of using a system call "S-Pod" but the cost was much higher. Here's a few pics. of my mods.
evildoctor
evildoctor
61
94
NC
5 6
T
taylorman
167
97
Lafayette La
Light in the bumper looks nice. What size is it and how did you mount it?
Reactions: evildoctor
evildoctor
evildoctor
61
94
NC
Sorry took so long to reply, im just seeing this. Anyways, it's a 13.5 and to make it fit in that spot you have to do a little pounding with a hammer. The lower left and right bottom corners of the inner openings of the bumper where I've mounted mine has to be bent in slightly in order for the led light bar to fit. As for mounting, I basically just bolted through each side of the threaded openings from the sides of the bumper. Hope this helps, I can post close up shots if you want...just let me know.
