![Sjc3081](/data/avatars/m/6/6724.jpg?1580674711)
I have a 18 1000-5 base. On the advise from Sedona Customer service and a not so famous Hf McCoy Mud Runner, I decided to get Sedona
Split Six beadlocks 14x7 5+2 off set. My tire choice was 28x10-14 RipSaws. After mounting the tires and wheels, my width increased to 67” front and 66” rear. For my type of riding the extra width was unacceptable. My first trip to HF McCoy I tore a front sidewall and was forced by tire availability to replace my front tires with Rockabillies of the same size.
Finally I discovered the STI HD9 14x7 beadlock in 6+1. I ordered two on a chance they will work. They are actually 6.5” wide as stamped on the inside of the wheel. I mounted my 28x10-14 Rockabillies on the HD9 wheels and they fit no rub at full lock and compression.
My inside sidewall did barely rub my Riccochet Arm are guards but a three pound hammer cured the issue. The 6+1 mounted on the rear caused my Machine to only 60” wide. I ordered some HD9s 5+2 and will update later. My width is now 64” max.
