Bradley-Thornton
So I looked at the main 3 options.
Cheap (Cheap doesn't mean bad) $40 (35AH CCA 264) 12 month warranty
Universal 45976 12v 35AH Sealed Lead Acid AGM Battery Apex Battery
The forum fav Odyssey PC925 $155 (28AH CCA 330) 24 months warranty They say on Amazon 3 to 4 but Odyssey say 2 on power sport. It is designed to run 10 years. batterieshttps://www.amazon.com/dp/B0002ILK72/ref=cm_sw_r_em_api_c_Kb79zbTAC8D4W
My pick XS D925 $169.99 (28AH CA550) 36 month warranty It is designed to run 10 years.
https://www.amazon.com/XS-Power-D925-Battery-Terminal/dp/B001GN0COE/?tag=sxsweb24-20
Note: The Xs D925 is tested at 32deg for CA the Odyssey is ran at 32deg for CCA on marine and the PC925 is in that class.
AH is also tested very different Odyssey test is a much lower standard than XS test at. Read Links for more info.
XS
Frequently Asked - XS Power
Odyssey
ODYSSEY battery - FAQ
Lets talk a little about the isolator the way it work is they are isolated till the alternator is charging and bring the Volts up to 13 Volts. It then opens so both can charge then when you cut the SxS off. It then fall below the 13 Volts and lets the start battery start the SxS and secondary be drained to run the extras.
True Smart Battery Isolator | TrueAm Dual Battery Isolator System
Now the thing I'm not sure about what I am going to do? Use the factory battery as the second and the XS D925 as the starter being it has way more Cranking Amps or the D925 as second.
Something else to keep in mind is the Winch. The bigger Warn Winch 5000k and up say you need a 650CCA battery. The 4500k winch says nothing so I called and asked they say it need CCA also but because you are so limited due to batteries in the ATV they not spec-if. They told me you should never run the winch without the ATV running due to CCA on those batteries. Point is I think the winch is really killing peoples batteries. So now I have to decide do I need the CA more for the Pioneer or the Winch.
Last thing if you live up North I think the Xs D925 would really work good for the cold with all those Cranking Amps.
XS
Odyssey
