P1000 Mystery connector
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
Anyone know what this connector under the front seat is for? 22 P1K5 base model
A58B7AAE EB67 4B92 AA84 1CE10C3C06CF
Reactions: Lady01
13,467
66,403
Along those lines, should these cables ties be attached to something?
Probably, I haven't been under the seat of a 22, or even mine lately to suggest routing.
Top open connector, you can probably move the harness into it. Then look around for a hole for the lower circled christmas tree.
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
There are two cables (throttle/shifter?) running through there. I think the loose tie downs are for those since they are just flopping around in there.
Reactions: Lady01
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
The unwrapped wire section is fairly short.
5076F630 C4E5 459D 814E 5A6D5034AD41
Reactions: Lady01
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
Next question, appreciate you guys humoring a new guy. Along the front edge of the front seat there is a connector taped to a bundle, looks similar to a 4 pin trailer connector.
694E7A52 C84F 4E2A 834D EABD4761B5B0
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
Am looking to mount my bilge fan but noticed “unused” connectors while poking around. No real sxs experience prior to this one.
13,467
66,403
What part of Ohio are you from?
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
Question #3…. Pulled the driver seat cover and found this, any idea what it is?
1770BECF 7B4F 48FE 9859 2AAB42609F24
JMynes
JMynes
543
3,231
Augusta, Maine
That’s a seatbelt strap thing. I think it’s for transport and supposed to be removed prior to delivery. I found one loose one (driver’s seatbelt) and three still installed on the other corners.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
If you're looking for some handy wires to hook up that fan under the seat, best bet is to run new ones! This is fairly easy to do going forward under the floorboards (remove skid pan if so equipped). There's a forward "access panel" at what passes for a footwell at the center of the front seat, it'll help some, as will experience fishing wires. Be sure to use adequate size wire for the current draw of the blower or fan you choose. 14 ga is great (following the rule bigger is better), 16 ga will do if that's what you got.
Reactions: Lady01
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
Thanks, planning to run new wires. I am just noticing things I had not noticed before while trying to fab a mounting bracket for the fan.
Reactions: Lady01
bumperm
bumperm
1,851
6,658
Gardnerville, NV
If you weld, the bracket I made is easy to install or remove - just two SS hose clamps. I welded the tubing to the bar at a compound angle to aim the blower. The end with the pin gets a bit of split plastic or rubber tubing to fit in the existing keyhole of the plastic intake resonator (or whatever it's called). Shown hung up to dry paint, in the house (wife is tolerant).
20211210 170308
20211210 212543
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
Looks great, things are a little tighter on the 22 with the under seat heat shields in place. They have "pockets" that drop down. The deepest one is directly over where you have your fan mounted. I think i will need to move it to the drivers side of the cross bar and angle it towards the exhaust manifold. Still fabing some left over aluminum to see how it will work.
Jankyeye
Jankyeye
602
2,709
Tampa, Fl.
Off topic from the original post but… Here is what I came up with using what I had laying around.
F8CF14AB 9368 439B B1DF 28FE53360D87
Reactions: Lady01
