Need help finding a oil drain plug for a 2022 pioneer forest edition
Red B
46
105
Arizona
Dealer gave me a part # of 15236-HL4-000 but I had to leave the area. having a heck of a time finding the right place to order. Where's the best place to order?
PS no dealer close.
Thanks Red
60,372
PS no dealer close.
Thanks Red
1687282265001
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
PS no dealer close.
Thanks Red
Any Honda auto dealer should be able to get you one, or any decent parts store as well. M12 thread, 15mm long.
Could be M12x1.25 or m12x1.5 grab both, throw out the wrong one.
Red B
46
105
Arizona
On the first oil change...they were on so tight that the husky 12mm wrench I used rounded the head. Had to get vice grips and a big ole boy to break it loose. Usually there's beer involved but not this time. Now on the second oil change I've got a slow drip. Dealer didn't have a new crush washer so here I sit. If I'm going to fix it I'm going back new.
Red
115,707
Red
Dont forget to hit the “reply” button then respond under that box so we get a notice that you replied to our question. ;)
Reactions: Backwoods
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
Red
If it can sit a week or so, buy what you need online.
I would suggest all 3 bolts, washers as spares. As well as the orings for the filter housings. And well, because you need them eventually. Order a few new filters as well.
Reactions: Scoop
Scoop
Scoop
5,140
20,318
  3. Talon R LV
Got it. The other forums I'm on you hit quote to do this. Thanks.
You use 'reply' with or without 'quote'. The difference is, 'quote' includes the original text from the post you are replying to.
HondaTech
Red
I've never had first oil change drain plugs that tight. Must be those garbage wrenches, ive always broken then loose with a ratchet and a socket. But a standard length wrench usually works as well.
