![Ca51flatty](/data/avatars/m/4/4630.jpg?1462464198)
A little help from an expert would be appreciated!
Looks like the joint connector 2 maybe???View attachment 38190 Does anyone know what this connector is for? Capped off under hood. I check out wiring diagram but I am not smart enough to figure it out. My guess is it is for accessory wiring?
OK, thanks. So if it is the Joint 2 connector then it more than likely it is for the Genuine Honda accessory plug in port?
I would say that's correct..
What are you looking to do?
Well, I'm sure you've seen what most everyone on here does..I am trying to add some accessories including the Honda horn kit (there are two listed) and I would prefer to use what Honda intended us to use but their accessory description sucks! No pictures, no instructions until you buy and other than the wiring diagram there is nothing in the service manual or owners manual about it.
My other option is to use an sPOD (4x4 SPOD Since 2005 - The ORIGINAL JEEP Over The Windshield Switch Console - Jeep Power Distribution System) system like I use in my Jeep but I am trying to learn about what may already be available
Thanks for the help.
