Just ordered the Viper 6000 wide spool winch and plate from here. Also ordered an under dash storage addition and a 52 inch light bar. Slowly getting there.
Just wondering the reason you would go low with a big light bar? The higher you can get that light the more coverage you will get down the trail or road. That's a 40" bar and it lights up the trail like it's daylight being up as high as I could get it without adding any height to the
Up high there can be some issues with the light reflecting and causing glare/wash out of the window. Two feet or less of height to me is not going to change the throw distance significant enough to worry about. Also it helps a little with the light not getting hit with branches and things as much.
Mine would never make it up there. It would be destroyed. Plus that spot probably wouldn't work with the flip up windshield. Definitely would put out more light though.
No it would definitely not work with the flip up windshield. I have the Kolpin metal roof and Kolpin glass windshield so it works perfectly. With it under the lip of the roof if it gets destroyed there you have way more problems than a couple hundred dollar light bar! Lol.
