P700m4 NEW MEMBER IN GEORGIA
rodroddy
rodroddy
I WANT TO INSTALL BACK UP LAMP. WHICH WIRE CAN I HOOK THEM UP TO? SO THEY WILL COME ON WHEN I PUT IT IN REVERSE.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
Welcome to the Club Rodroddy!!
67,170
Hi @rodroddy,
Welcome to the club!.
This method will work if you do NOT plan to install the reverse override.
See this 3 wire connector at the passenger wheel. The GREY wire is a ground when in reverse. (test light it to make sure i'm right) Use this as your switch point. Run a positive to your light and the negative spliced to the GREY wire. Now the light will come on when in reverse!
Gps jpg1469
Reactions: mrjeff42
