New tire psi
F
Fischer
209
321
The woods
I finally got rid of my stock tires on my pioneer 500. Which they recommend 10 psi. The new tires tusk terraform, on the sidewall, it recomends 7 psi. Is this to low? I called the company and they said they can't recommend going higher than the sidewall says. Any thoughts on this? Thanks.
Backwoods
Backwoods
35,776
362,056
Douglasville ga
What is the side wall marking?
AT tires are for ATVs and usually have a low pressure.
NHS are for SxS (and other stuff) and usually are ~30 psi max.
I'll look in a bit I just got home.
43,292
A lightweight machine like the 500 should be well down in the single digits with a 6ply unless you're hauling lead ingots stacked to the top of the cage. I think I ran 4-5 psi on mine, though I concede I favor ride over handling.
That was a 6 ply. I can't imagine what kind of hell a 500 would be on 10ply tires...but I'd only have the valve cores in to keep water and dust out of the tire.
The Green Goat
The Green Goat
2,251
16,621
Ohio
