Talon New tires and wheels on the talon
Cowboy02
Cowboy02
60
136
Northern Ca
  3. Talon X
IMG 1218
IMG 1219
IMG 1220
IMG 1221
Cowboy02
Cowboy02
60
136
Northern Ca
  3. Talon X
Are they 30's? Looks good
Yes they are. After months of talking to wheel manufacturers, different people in our side-by-side club finally settled in with the system three wheels.
Reactions: BWAF
jamesparisp5
North Carolina
looks great first time posting anything did the 4x3 and 6x1 offsets work out for same width front to back I’ve been waiting to hear
Reactions: BWAF
Cowboy02
Cowboy02
60
136
Northern Ca
  3. Talon X
Pretty close. The rear is 3/8 inch narrower then the front, and the overall width went from 64 1/2 to 66. I think if I had to do it again I would get six by one offset all the way around and do the spacers so you could rotate the tires. It really handles the 30 inch wheels perfectly.
jamesparisp5
North Carolina
Hometeam
Hometeam
995
4,155
Normal, IL
Do you know the weight of your setup? I like your setup a lot. I am looking for a wheel/tire combo on the lighter side if possible! Thanks
Cowboy02
Cowboy02
60
136
Northern Ca
  3. Talon X
I did not weigh them. But the tires are definitely heavier do too 8 ply and DOT rated
Cowboy02
Cowboy02
60
136
Northern Ca
  3. Talon X
IMG 1222
What spare carrier are you running? Is it hinges so you can access the bed?
Talon looks great, my system3 and 31” carnivores will be here this week!
It does hinge from either side but you have to pull The Carter pins . Here's a picture of it on the Internet
Reactions: CincyCuda68
Kevinka1977
Kevinka1977
70
73
Washington
Cowboy02
Cowboy02
60
136
Northern Ca
  3. Talon X
Looks great! Did anyone you talk to advise against 32” tires on the X? I’m debating with the 32’s or 30’s...
Also when you swing the spare tire out does it stay put on its own? Or do you have to support it? I have the factory Honda hard storage that I would need to get in and out of...
I never asked about 32s because I was just interested only in the 30s. As for the spare tire rack when you swing it over the rollbar it will stay in place I don’t normally do that. Check around they’re making a lot of cool spare tire racks nowadays
Reactions: Kevinka1977
Kevinka1977
Kevinka1977
70
73
Washington
Awesome thanks for the info!
HavasuDave
HavasuDave
164
307
Arizona
I went with 30's I think next time I'll go 32"
