P1000 New tires for p1 HELP
K
kennyg68
16
Medford, Wi
I am new here, hope I am in right place. I am thinking about putting Wanda or ocelot 27 12 12 on my ipt 312's on p1 are they true to size. I am worried about stories of under sized ads. HELP
Reactions: Isaiah and TxDoc
208,726
Welcome to the forum from Mississippi. I can't help you on that but someone should be along shortly to guide you in the right direction.
I'm a big fan of ITP tires, made in the Good Ole USA, think they have three different tread patterns. Happy trails!
208,726
Welcome aboard from Northeast Texas! Depending on what type terrain that you have, Mud tires are as suggested ITP. If you want a long lasting All Terrain, I really like my Tusk Terrabytes from Tusk Terrabite® Radial Tire plus you can get whatever you want from them. Tusk Terrabite® Radial Tire
My ITP Terra Hooks aren't mud tires, the Black Waters are close to a mud tire, they clean out very well. had a set.
bigshoe
bigshoe
422
1,427
Im running Wanda's 27-9-14 on front, cut a side wall on bighorns and rear still looked pretty good. so I bought something to get me by till rears wear down. There pretty close to size but lugs where smaller. The sunf tires have bigger lugs
bigshoe
bigshoe
422
1,427
A word to the wise if u can afford it buy name brand tires. I got 170 miles on the Wanda's and they look like sh##. There not gonna outlast the rear bighorns with 1800 miles on them. Made a bad decision went benefit ride that was 70 miles of pavement and 3 miles gravel road and absolutely smoked them.
Backwoods
Backwoods
35,248
357,933
Douglasville ga
Look at ITP terra claws they look really good and should be an excellent product.
Reactions: Isaiah
K
kennyg68
16
Medford, Wi
Thanks for all the replies. I ride fairly slow & on trails, very little pavement. I maybe a little old school, but I like a wider tire (for looks) I was looking for the widest tire to put on my 12x7 wheels I made my original tires on a 700 last 7800 miles. Thought the Wanda's were a fairly cheap way to go. MAYBE TOO CHEAP?????
Reactions: Isaiah
gparks
gparks
1,289
16,216
Asheville NC
  1. Talon X4 LV
Can you put the 27x11 stock tires all the way around on a P1000-5 or will the be to wide for the front?
Reactions: Isaiah
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
27-11 on the front with no wheel spacer may be a problem, depending on wheel offset. 27-10 would probably work better.
Reactions: Isaiah
gparks
gparks
1,289
16,216
Asheville NC
  1. Talon X4 LV
Ok thanks it was worth a shot. I was hoping with them being stock rims I would just be able to put them on and go.
Reactions: Isaiah
JenElio
JenElio
73,347
667,343
Loxahatchee, florida
The tire isn't the issue, its the rim. The rear rims are a 4+3 offset, without a spacer the rim hits the upper a-arm/shock mount area at full turn. At least with the 12" rims, I've not checked with the 14" rims. But I believe a 1" spacer will fix the rubbing issue.
Reactions: Isaiah
gparks
gparks
1,289
16,216
Asheville NC
  1. Talon X4 LV
Oh ok so I couldn’t just have the tire mounted on the front rim
Reactions: Isaiah
Sjc3081
Sjc3081
263
442
Wappinger NY
The rear A Arms are a 5+2 aftermarket offset using STI HD wheels.
