New winch/kfi mount installed
zrxrob
zrxrob
41
5
Man I can't stop adding stuff to this thing 281e3cfa76281727893acd823dd9b727
Realtreegrizzly
Realtreegrizzly
38
16
I just put a 2500lbs winch on my 700 that I had off my atv I traded in and was wondering if I decide to put on a 4500lbs winch if I'll have to change the wiring and contactor. From looking on the winch manufacturers websites they only sell one set of wires and contactor.
66,429
Realtree,
Generally, no. It should be fine.
But take a look at the wires. If the 45 wires are larger, then I would have to recommend changing them. Most likely the will be the same. The contactor will be fine. Save the new one for a backup.
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Realtreegrizzly, I went from a warn 2000 to a warn 4000 and the wires and contactor were NOT the same. Wires for the 4000 were heavier gauge and contactor was bigger. What I would recommend, and what I will do eventually, is mount the big winch on the front and the little one on the rear, assuming you do have to change out wires and contactor like I did.
66,429
Yep.. change them.
Old and newer warn 2000 uses 8g wire.
4500 uses 6g.
KFI sells the exact same wire for all their kits.
You don't want to put a undersized wire if it overheats and burns through, there is no fuse to blow and it could burn the whole thing to the ground. There is a lot of power stored in that little battery.
Realtreegrizzly
Realtreegrizzly
38
16
Just got a email back from my winch manufacturer and the wiring and contactor is standard with all thier atv utv winches
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Hopefully it's because they use the heavier wire on the small ones not lighter wire on the big ones!
Not sure about others but the KFI wire is 6ga for all winches. So far I've had no issues out of it.
