P700 No start in 700
Hunter92
New Zealand
Hey guys just brought Honda pioneer 700 2018. Test drive it everything working as it should be. Then travelled 2 hours home. Gone to take it off the trailer and I have nothing coming up in the dash it’s turning over but not firing. Have checked and pulled all the fuses out checked the battery and it has my stumped. Any help would be greatly appreciated.
115,792
Check all your grounds and make sure there good And that a connection didnt come loose.
And welcome from the States!
Dont forget…
Pics Or It Didnt Happen!
of your machine. ;)
Glock21user
Glock21user
" Nothing succeeds like excess "
1,815
9,039
Livingston county, Mi.
Also check the status of battery charge.
I know it sounds silly but it is a real issue with a b.s. small battery.
Reactions: swsebek
BigMac
BigMac
48
92
I had hard starting problem when warm on P700. It was the stator shorting out. Was told battery was fine to turn over engine but ignition or fuel injector required more voltage than battery alone supplied and that power needs to come from stator with good connections.
You may need help checking voltage when it is turning over. Has to be over just battery volts.
