P1000 Noob question
E
EMS_Capt
Longview, TX
I'm new to the forum but have been reading lots of posts and getting ideas for several weeks now. Diving in with the addition of a radio and winch so I will be installing a second battery this weekend and a switch plate. I will be using a True isolator, circuit breaker, and stinger relay, along with a 6 circuit fuse block for accessories. My question is this, my radio has an inline 40amp fuse which I will leave alone and attach to the stinger. Are there any issues if I still attached the ground wire from the radio to my fuse block?
Reactions: Ragnar406 and sharp
322,675
Ground wire on fuse block? You mean ignition wire?
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Some fuse blocks have a ground. The answer is no
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
Yes this fuse block has a grounding bar.
Nope - that is how I have mine
Reactions: CumminsPusher
