Not hitting top speed
jjc1000-5
9
14
Ohio
Anyone ever experience an issue of not hitting max speed? I have a 2017 1000-5 and it will start fine, idle good, and run great. However when I try to open it up I can only got 42-43 mph as opposed to the 68 mph I used to get. Im wondering if its a fuel filter/pump issue???
208,728
Air filter?
Reactions: TxDoc and TripleB
jjc1000-5
9
14
Ohio
Air filter has been checked. And is brand new.
Reactions: TripleB
William
William
1,442
2,887
Flowood MS
What tires?
jjc1000-5
9
14
Ohio
Stock Maxxis tires. @Smitty335, this seems to have started right around when I added a snorkel. I think im gonna unhook the snorkel at the intake and see what happens........
Reactions: TripleB and JenElio
JenElio
JenElio
74,953
676,510
Loxahatchee, florida
I doubt the snorkel is depriving the machine of 20+ hp, if anything you might have somt'n stuck in there from the install. My buddy noticed a loss of top speed after his snorkel (top speed of 60ish) but nothing close to what you are experiencing.
JenElio
JenElio
74,953
676,510
Is it going into 6th gear? Are you over revving at 42-43?
jjc1000-5
9
14
Ohio
It is going into 6th gear. And just acts like it cant go any faster than 42-43
JenElio
JenElio
74,953
676,510
Have you tried running it in manual? Or sport mode?
jjc1000-5
9
14
Ohio
Does the same in manual and sport mode. HighLifter snorkel.
JenElio
JenElio
74,953
676,510
Dang man, I would check for somt'n blocking air to the intake.
How about the rpms when topped out?
Reactions: TripleB
jjc1000-5
9
14
Ohio
Im going to go through intake to the air filter box and inspect and clean if needed. Will also check and clean spark arrestor. If nothing significant there I will unhook snorkel and see what happens. Will let you all know, and thanks a lot for the help/suggestions!
