Note to Honda
Dan Lawrie
Dan Lawrie
40
80
Las Vegas, NV
Honda you are building a great product in the p520. I just wanted to give some customer feedback.
1, Make the screen a little bigger so.
more than I item can show at the
same time.
2, Enlarge the fuel tank. There's plenty of
room under there.
3, Put a heat shield under the seat belts
so they don't get so hot.
4, Make the cup holders wider so it
actually hold an insulated cup.
5, Move the oil filter saccessible.
accessable..
6, Possibly add a 6th gear for a higher
top speed.
These changes are not very expensive and would make a huge difference.
Hello_Darkness
Hello_Darkness
671
2,709
Just to the right of nowhere
same time.
room under there.
accessable..
top speed.
Moving the oil filter location isn't expensive?
Just redesign that engine real quick.
Todd627
Todd627
57,271
624,801
MI
Ya it would be real tough to give access from the bottom. A hole in the skid plate would cost millions. Your not a very good mechanic are you.
You originally said “move the oil filter” which is very different than simply putting a hole in the skid to access the oil filter.
For the record, you are picking a fight with one of the best (if not the best) Honda Tech in the country. He has the trophy to prove it.
Hello_Darkness
Hello_Darkness
671
2,709
Well.....👀
20250115 190944
Jerryg
Jerryg
12,255
96,704
NEPA
7. Stop making outdated machines with poor quality control.
GovtMule
GovtMule
21,925
187,320
Tennessee
8. Adapt to what you have and don’t complain about it. If you are that unhappy buy something else. 🤷‍♂️
Reactions: Robobrainiac
195,424
All of these suggestions were made 10 yrs ago when the 500 came out. It comes down to wants and needs and it was designed as an affordable utility machine, think of it as an ATV with a second seat. Honda built the smallest and most dependable sxs on the market with all the necessities so, realistically, they nailed it.
After working and beating the snot out of one for nearly a decade my suggestion would be... don't f*** with it! 👍
DRZRon1
DRZRon1
1,445
4,404
PA
This tech has helped countless on here out of a jamb, saved em money and reduced their stress level. He is a pro, does this every day and I believe stayed at a Holiday Inn once.
You wanted a relocated oil filter, not better access - as usual he is spot on.
Rdrcr
605
3,270
WA
I like #6. I’d like seeing the P520 with an additional gear for higher traveling speeds.
Mike
DRZRon1
DRZRon1
1,445
4,404
PA
spot on - redesigning a reliable 10 year old workhorse 🤪 !!!
Reactions: Rayger143
283,025
same time.
room under there.
accessable..
top speed.
You will get bold new graphics every 3 years and like it. 😁
Reactions: futzin
