I just bought a used 2016 1000-5. The aftermarket harnesses installed in the front are ratty, so I am replacing them with OEM 3-point seat belts. There are no instructions included with the seat belts and I haven't found any online. The lower end of the belt has a shoulder bolt, two teflon washers, the plate at the end of the seat belt (not sure what that part is called), and a spring shim; is this the order that the seat belts are installed at the factory? It would seem like there should be one teflon washer on either side of the seat belt plate, but I don't have a convenient stock example to check.
