P1000 oil pressure and clutch temperature
L
luarbes
COLOMBIA
  1. 1000 6 Crew
Hello, I am coming to you for wisdom, I am from Colombia, I have a Honda pioneer 1000-6 CREW model 2024, I am having the problem that after approximately 20 minutes and when it reaches 100 c ° of operation at idle the car turns off, I have to turn off the contact to be able to turn it back on, but if I keep it at idle it comes back on and turns off, instead when I keep it above 2000 RPM it stays on, but the oil pressure indicator and the clutch temperature indicator turn on, but I have already changed the oil for new ones, changed oil filters, checked the lubrication pump, fuel pump, injectors, electrical system, replaced the computer, replaced the air control unit and the car continues with the same fault. I would like to know if this has happened to anyone else and how they solved it. I have dynamic test log information recorded with the ECM unit, I also tried to perform clutch initialization through the ECM unit but the SXS does not respond to it, just thinking until it is cancelled. If someone can help me read it and solve this problem
T
tbaker
371
650
NW. Georgia
That sounds like a trip to the dealership. You didn’t say how many miles you have on your pioneer .
L
luarbes
COLOMBIA
  1. 1000 6 Crew
My pioneer has only 1800km which is about 1000 miles, I took it to the dealership and they practiced several dynamic tests and they are trying to solve it but they don't have any concrete answer, because they tell me that these SXS are manufactured in the United States and they sent several tests to the headquarters but they can't find the failure, I think it's best to request a new unit.
