P1000 Oversized blank switch
N
Nlviking
22
68
Canada
I have a pioneer 1000-5 Deluxe. i did a few mods already with gear from the club store.
One thing, I have been trying to remove the blank switch plate next to the AT/MT switch but with zero luck. I am trying not to break it but want it out. I can almost touch the back of it but my hand gets jammed. I assume there are tabs that need to be depressed?
below is the pic I clipped from the club store so you can see what I trying to remove. Anyone have any ideas..
1A8E2D4B CF72 410F A395 EF4F9CBEC513
GovtMule
GovtMule
16,337
155,643
Tennessee
I got mine out and using my Dremel hollowed it out to put my corded winch remote plug there. I “think” I just pried it out and it popped right out. Can’t remember for sure.
4A7D44BF DB56 4711 BA18 AE9A9F0D6979
66,853
Tabs on the top and bottom. Squeeze and push out.
Can't give any other info as I have not personally removed one from this location yet.
Thought I had a blank at the house, but I don't.
GovtMule
GovtMule
16,337
155,643
Tennessee
That sounds right. I think I got it from the back side. (nomo) 😆
  • Haha
Reactions: JenElio and CID
N
Nlviking
22
68
Canada
Hard to get you hand in there but will try again. Will let you know.
115,420
66,853
Insert a pic at the top and bottom about 3/4 inch. But no guarantee it won't dimple it where the pic was.
N
Nlviking
22
68
Canada
Hello all
I tried using my hand to reach the back but not luck without removing a few things. I was too lazy.
So I used the edge of of a ruler to push out the clip at the bottom. It took some effort but after I heard a click sound the bottom of the blank could be pried out. I had to insert the ruler in by close to one inch.
965646B3 840C 412D 9E4B B910C8634A01
the blank looks like
F675A597 E16C 47C8 94D3 F9A7C2E1EC67
the final result was a horn switch. I used a blank to hold the switch I had on hand. However it does not fit well so I will need to buy the blank on the club store
8AAA39DF C8CA 456E 9E50 42A69A4E890B
thanks all
