P1000 P-3 no power out put
T
Tylergduncan
Tylertown MS
My bike runs fine on the road or on a trail but last night I got in a mud hole and it wouldn't even spin the tires over acted like it didn't have any power at all. The RPMs won't get up so I know it's not the clutch slipping.. And yes it was 1st gear low. It does it in 4wd and 2wd.
amc019
amc019
480
592
Little Rock, Ar
Sounds like you need to make a trip to the dealer. Are you still running the stock tires? Did you lose all momentum when you went through the hole? The only way I can see a problem is if you didn't keep the tires spinning. With the clutch these things have, it will not be good for the tranny to stop and then try to get the tires moving under load from a stop.
Tot
Tot
661
462
Des Arc, Arkansas
That's weird. I was driving yesterday testing my new truck tires and almost got stuck, tires caked over. I put it in R and gave it some gas and it pulled back the put it in L and gave it the gas and mud went flying all over the place.
T
Tylergduncan
Tylertown MS
I have no idea what is going on going to bring it in the dealer tomorrow.
