P1000 1000-3 maintenance question
K
Kelldog
55
120
I installed a full skid plate so obviously i cannot determine what drain plug is what based on a close up pic of the drain plug with no skid plate around it. If that makes sense. So looking for a single picture of all the drain plug locations with the description. With the idea i can go by physical location of the overall machine to locate which one it is rather than the hardware around the drainplug for identification . Hope this makes sense
Reactions: TxDoc
5,750
26,399
I had the same problem with my Talon, replaced the skid, had no idear where the drain plugs were. :oops: Although this is a stock Talon skid, the drain plugs are in the same place as your P1K3 -
1730516936422
