P500 P 520 Rear Abnormal Tire Wear
G
grease monkey
31
211
illinois
I do a lot of hard surfaced road driving between farms. This is the second set of rear tires on my P 520. Granted, I've got 7700 miles on the lil work horse, but the passenger rear tire wears twice as fast compared to the driver's side. I saved the original (factory) tire that was 1/2 wore out, figuring the 2nd set would probably wear the same. So I changed out the wore out passenger with the original 1/2 worn out tire to have a match set. Almost seems rear passenger side suspension needs more camber in the A-arms. A-arm bushings aren't worn out. Any other P 520 owners having the same issue? TIA
Rear Tire Wear
Rear Tire Wear 1
Red500
Red500
6,631
71,187
Greeneville, Tn.
At first I was going to say over inflated but a closer look tells me I have no idea.
Reactions: Backwoods
G
grease monkey
31
211
illinois
Been running 10 psi on all 4 corners. Still have the original front tires on it. Front tires are about due to be replaced.
Red500
Red500
6,631
71,187
Greeneville, Tn.
If it was a front tire I would say check you toe in or out because they are notoriously bad but on the rear IDK.
The Green Goat
The Green Goat
2,444
17,994
How much does your wife weigh? Check that first and report back.
