P1000 P1000-3 hard door stop straps
A
Ariestmh
Colorado
Hey guys I have a p1000-3 with hard doors and my door stops broke and I am having a hard time spending 53 bucks on them. Was wondering if someone has a work around. I searched the forums and tried the chain idea but when you close the door the chin binds up and won’t let the door close. Anybody have any ideas?
BAC199DA E55A 4536 A4D2 24937AB96219
Reactions: Lady01 and CMB
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Maybe try using an old piece of ratchet strap ?
bumperm
bumperm
1,899
6,778
Gardnerville, NV
I'd stay with a nylon or similar strap for the slight stretch or give as it come up to the stop. This is easier on the mounting hardware etc.
Reactions: Ariestmh
slowdryrider
slowdryrider
572
778
Canada
I made up my own from the end of a ratchet strap . Figured out what length I needed and with a needle and thread made my own.
A
Ariestmh
Colorado
Looks like I will have to try the ratchet strap idea. I did put a bungee cord on the chains to pull them up when the door closes and it seeems to not let the chains bind when closing the door.
Neohio
Neohio
Beast of the East
14,587
73,820
Painesville Ohio
If you don't want to sew a piece of webbing/ratchet strap.
Use a nail or soldering iron to poke holes in the webbing, then use pop rivets with a washer to hold it together.
bumperm
bumperm
1,899
6,778
Gardnerville, NV
I've also had reasonably good results bonding the nylon strap with hot melt glue. I used that for the hold downs on my aux battery and it works well. I don't suggest this for higher loading though, especially without testing, though it could be used in conjunction with @Neohio 's post.
