P1k5 shifting problems. Please help
X
X502XGEOFF
7
5
Kentucky
2016 p1k5 revs between shifts. Thought it was clutches. Replaced both clutches, removed and cleaned lubrication system. Put back together and still have same problem as before clutch replacement. Thinking maybe dual clutch pc solenoid valve is the problem but not sure exactly what it does. Revs between gears in AT and manual and in between all gears. Does pc solinoid control pressure (speed) to the clutches? Any help would be appreciated. Thanks in advance!
Reactions: TripleB and TxDoc
X
X502XGEOFF
7
5
Kentucky
16040768789412805401540172980460
Reactions: TxDoc
JenElio
JenElio
74,981
676,635
Loxahatchee, florida
Sorry bud I can't be of much help on this.
Maybe @HondaTech
Reactions: TripleB
322,675
Did this just all of a sudden happen, was there anything that lead up to it? How did the clutches and oil look?
X
X502XGEOFF
7
5
Kentucky
Clutch engage when taking off i never thought it felt right. I want to say it happened suddenly. I ordered pc soleniod and shift solenoid putting in today. I checked clutches when i took out and they were still barely in spec but changed to new anyway. Oil was pretty bad. Had a good ammount of friction material in it. Going to take apart the valve today. Hope it works if not im dead in the water. Thanks
Reactions: TripleB
322,675
Hey make sure to clean out the filter screen material too.
Reactions: Mudwing
Major0887
Major0887
30
60
Arizona
Has this been solved? Mine is starting to rev between shifts too. Mainly shifting between 5-6.
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
Anyone ever find a fix for this? Mine started doing this many, many miles ago. Extra oil helps for a little bit but it goes back revving in between gears.
5,488
25,255
Have you tried the clutch relearn procedure? There's a video linked in my sig thread, Pioneers relearn the same as Talons.
Reactions: TripleB
60,948
Do you have a PowerVision? You can adjust the clutch engagement with the PV3. Mine had what I can only describe as a "soft shift" from 2-3. I threw the PV3 on there and even with just the DynoJet canned tune, the shifting is WAY better. It engages much harder and my issue completely went away.
