P1000 P3-1000 Home made doors
322,690
Ya I did a set. Bit time consuming but not really too bad. When I did them there was nothing available and I had chopped the cage so was only option.
E8253F7B ED43 4998 ACEE 7B2469307829
2D4EA670 1AF8 457F 9343 F27E5073F774
322,690
Did you make a frame then cover with metal?
Actually the front doors were a dense plywood fiberglassed over. The rear doors and back window I went different route with expanded pvc sheet. The plastic was much easier to work with and quicker but had to be slightly reinforced with aluminum angle.
322,690
Here’s where I started the project. Excuse the banter, we all use to bs a lot lol.
Might be some ideas that would work for you in different ways. Most important thing is to build an easy template with whatever material you might decide on.
MuddHonda
MuddHonda
55
159
Fredericton, New Brunswick, Canada
Are you still using the plywood front doors or did you change to PVC?
322,690
Front doors were done with ply but hand laid fiberglass over them. Tbh that was a pain to do and quite frankly overkill. Just a dense plywood would be fine, someone would just have to make sure they are sealed from the elements. I never changed them up. Like said the rear is expanded pvc which is much more expensive but very easy to work with.
