P5 running 29.5 outlaws?
63,891
This video shows a Pioneer 500 claiming to run 29.5" outlaws. The video is not that great quality but it seems to turn them just fine. We do know a p5 will run 28's with the frame mod. Do you think its possible to turn a 30" tire?
Reactions: trigger and rocmar
michaelbach
48
7
Re: P5 running 29.5 outlaws?
That's badass, I just wonder how that will wear on the transmission
Reactions: rocmar
HondaTim
HondaTim
203
40
If the tires are true to size that's impressive. Is anyone running big aggressive mud tires like that on the 700's? Video would be nice hint-hint
Chadmassey
7
0
0
Figured the drivetrain would pull 29.5s just wondered about clearance since you have to trim for 28s. Have a buddy running 29.5s on a foreman so the power is definitely there on a p5.
SouthGA
SouthGA
61
127
Well I got a set of 29.5 Outlaw 2 on 14 inch wheels coming in tomorrow. I done the frame mod and will update tomorrow . I know everyone is wondering just like I am. I may regret it but we are going to see. Decided to wait on a lift kit and see how the outlaws sit on stock. Gonna be a big jump from my 27 inch Dirt Commanders. Mud Life Baby
Reactions: joeymt33
rocmar
rocmar
4,741
5,773
4 CORNERS
I hear that...
29.5 outlaws
ain't 29.5....
with 8psi
SouthGA
SouthGA
61
127
I hear that...
29.5 outlaws
ain't 29.5....
with 8psi
That's for sure. I will see where the psi works best on the 500. I run most of my tires low pressure anyways. I never ran on a set of 14s though so new territory for me. I have always likes 12 inch wheels but you have a lot less options IMO.
SouthGA
SouthGA
61
127
Hd4
Went with these wheels
rocmar
rocmar
4,741
5,773
4 CORNERS
So...wats the weight difference
in stock...to them?
Im not sure but I would quess thier at least double the weight of the stocks if not more.
That's a good thing, more weight on the bottom, better for stability.
SouthGA
SouthGA
61
127
The 29.5 are awesome. Alot of weight for the 500 so you ae gonna run mud in low gear and second. They are gonna scrub the floor pannel even if you do tbe frame mod as i did. Will bind down in super thick mud so you gotta know when to say when. All in all i am super impressed with the tires and plan on running them for awhile. Will update later.
pFive
pFive
670
1,267
Greenwood IN
I run narrow 30's and I like them. Here is a video of some wet mud, the kinda mud that would take your boot off if you got out to push.
I am not wringing it out really hard because I had a young passenger and was demonstrating that you do not need to go through water like your hair is on fire.
Its really low res, the guy that took it needs to up his memory I think.
I think it was second gear.
