Ok i did a half ass frame mod about a month ago or so just to see if my wifes 30x12x12 mud tires would fit off of her p700. I never capped the frame after i cut it because i knew i would be getting these 30x10x14 monster mayhems and i wanted to see how they rubbed. They did rub so i cut it back a little more. I just kinda copied the contour of the plastic floor pan. I plasma cut the frame rail and crossmember pieces out. I know it kinda looks rough. Im gettin kinda shakey these days with the plasma cutter lol. I cleaned it up with the grinder and cut a piece of cardboard out to fit in the frame cutout. Once i got the cardboard sized right i transfered the shape of the cardboard to same plate steel and plasma cut it out. Cleaned it up and kept hammering on it until i got it to match the curve of the frame cutout. I welded it in and wire wheeled everything. Cleaned it up and painted it with a couple coats of gloss black. I put the wheel back on and turned it full lock to the passenger side and ive got about 1 1/2" clearance between the tire lugs and the frame now. I only had time to do the passenger side today. I'll probably jump on the drivers side tomorrow sometime or monday. Anyway, heres some pics of the process. I hope you like!
