P500 p500 shock upgrades
The Green Goat
The Green Goat
2,433
17,928
Ohio
I just need something that won't lift a tire off the ground when I drive over a twig, lol.
Man, if that's all you want, then don't overthink it. Throw on a set of Walkers or Elkas and save yourself the headache. You'd probably be surprised at the articulation you get with a set of those.
Driving with stock shocks is like driving a 2x12. Adding aftermarket shocks fixes that.
futzin
futzin
4,807
35,244
Kentucky
Its so close. 60" for me is really pushing it beyond what I want... 62 isn't much different but it really kills the concept. I'm fine with no power. I just need something that won't lift a tire off the ground when I drive over a twig, lol.
I totally get wanting to stay under a certain width.
I will say that a 53-55" P5 with either Elkas or WEs is pretty damn fun. 26 or 27" tires on 12" 4+3 offset wheels, maybe spacers. . .
But I believe the travel is limited by the A-arms, not the shocks.
195,885
Odd. From what I can tell, no one has said anything TO listen to? Lol. Mr hot shot trigger didn't even address my question, he just talked about why I shouldn't ask it.
From what I can tell you won't listen anyway and I did address your question without getting into the particulars but if you need to hear it... you're going to be limited by the right front axle. Raise your machine to full droop and spin the right front wheel, feel that hitch in the giddy up? That's the CV that's maxxed out already. Pretty sure Elka and WE's engineers R&D'd to get the maximum amount of safe travel out of their shocks already. Look at any P5 with spring spacers, lift or even the posted YT video with the Ebay shocks, the camber on the front wheels is jacked. It might be a way to get a little more out of it but it's a dumb one. Just bc you can doesn't mean you should. You can also shim the front differential but any amount of added travel will be minimum unless you start seriously modding and then your wanting to maintain 50" goes out the window.
You bought a machine with little suspension travel but it fills a niche. It has a shorter wheelbase than the other 50" machines you referenced but they won't fit into the places this machine does and aren't as reliable. There are several things you can do to give it a better ride without DIY reengineering. Like the rest of us you picked your poison. If the solutions given still don't fill the hole in your heart you probably should've bought a different machine.
Still want to discuss or just b!tch?
GovtMule
GovtMule
22,033
188,055
Tennessee
This might have been discussed already, but what kinds of plants do you dig?
20210616 181220
Todd627
Todd627
57,285
624,965
MI
IMG 3091
I
idiggplants
19
35
Pa
See, now why was that so hard? An actual discussion instead of just being rudely dismissive. You can't tell if I "won't listen" when you previously had said nothing but rude dismissive stuff. Simply saying "the cv joints can't handle more angle than the oem angles would have answered my question better than the way you originally did.
What I don't understand is that lots of folks on the groups are using 1.5" lifts with no issues. Are they lying?
The cheap ass banshee shocks seem to give more up travel than oem. With only 0.5" additional down travel. Whats your reasoning for avoiding that type of increased travel, if I don't have clearance issues with my tire setup?
The elka and we engineers really seem to take oem shock travel and just added better valving and spring rates. I'm yet to see them mass produce anything other than oem travel specs. And that goes for any machine, not just the p500. On machines that people almost always lift... Like the RZR 50" and 60" models, the story is the same. They only produce oem shock lengths and then people add lift kits to them. And lifts definitely are fine on those machines. Nearly half the machines on the enthusiast groups/forums have them lifted... So you could apply the same "they engineered it and they know what they are doing" logic to that situation, and clearly that wouldn't make sense... I've never understood why their wasn't a bigger market for longer than oem shocks. It seems like an untapped market for both elka and WE.
Reactions: JenElio
P
pappyo
613
2,454
Many good people and information on Honda pioneer Forum
TUDES are Free <> or <> ( Dime a Dozen --- If use C.C. )
I
idiggplants
19
35
Pa
All sorts. I started as a landscape architect/horticulture degree before going into civil engineering. I'm just pretty much a fan of the outdoors and forest and environment. Forest ecology will always be my true passion that I could never make an actual living off of. Instead I hunt and fish and ATV and hike and volunteer.
As for the mary jane... Meh. Not really a fan, but I'm not against it. Kind of bummed I missed the legal stage of things when I was younger because I probably would have enjoyed the horticulture side of it.
pretty sure those poppi's are not the ones used to produce opioids, but they are pretty at least. Annuals(and herbaceous plants in general) are probably the types of plants I'm least into. Woody plants, shrubs, trees and such are more my thing.
futzin
futzin
4,807
35,244
Kentucky
No one here has a lift on their P5, to my knowledge. Also very few dedicated mudders, portal people, etc if any.
Very little overlap between forum members here and the FB stuff, pretty sure.
I
idiggplants
19
35
Pa
If that's the case, then I can see why increased droop would not be an option. The fb groups definitely have a lot of people with lifts, but I'd consider the fb groups in general not good sources of... Well... Anything. Is there similar concern with increased upward travel, outside of tires rubbing?
Reactions: MiniRF and JenElio
JenElio
JenElio
82,553
716,489
Loxahatchee, florida
So, I'm no expert on the P5s by any means but.....adding a "lift" and suspension travel are 2 different things. From what I've read from you posting here, seems you're associating one with the other. A lift will give you added clearance, whether under belly or wheel well, it's just a clearance issue. You're wanting to add suspension/wheel travel but unless you modify either the a-arms/mounts/axles AND shocks...... So like hot shot trigger mentioned, your stock set up will always be limited to your current design, mainly because of the CV.
I think you should find someone near you/local with a P5 and upgraded shocks and ask to take a ride. Like everyone that's upgraded shocks has mentioned, you'd be surprised at the overall difference.
