P700 P700 downshifting hard
walexa07
walexa07
396
380
Louisiana
Thanks in advance - a buddy has a P700 that he says downshifts hard. Was this ever a problem with the P700, and is there a fix? Or is it normal to capitalize on engine braking?
Thanks,
Waylan
Mudwing
Mudwing
36,959
306,670
The Mud holes
I don’t know if it was a problem but mine shifts up and down smooth. How many miles are on it? The engine braking is around 9mph.
walexa07
walexa07
396
380
Louisiana
It's very low mileage.........does the engine braking come on hard around 9mph?
Thanks for the reply!
Waylan
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,670
The Mud holes
Waylan
I’d say it brings it down to around 9mph. If the oil is good, he’s probably good. Putting miles on it only makes it better. It’s all gears and shafts. You learn to drive with the pedal. It wakes up around five hundred miles or so. The 7hundo is solid. Now if he’s hearing clunking or banging, then he should check it out. 😉😎
42,681
Closed throttle...like coasting into a corner, it would be a bit jerky going down. Likewise, climbing a grade and having it downshift would usually throw a bit of roost as it grabbed, but in that situation it kinda had to. Always thought the 700 shifted quite well.
Reactions: Mudwing
Russ989
Russ989
22,639
147,230
It depends on his definition of shift hard, my 700 would shift down good but if trying to slow down quick it may seem like it’s a hard shift. It’s probably normal, the 700 tranny is tough.
Reactions: Mudwing
walexa07
walexa07
396
380
Louisiana
Thanks guys for all the replies. I think what he is experiencing is normal. Said it’s done it since new.
thanks again!
Waylan
Reactions: Mudwing
