Paddle shifter on a Pioneer 700
68,397
Who is going to to be first to install the paddle shifter on there 700?
With some clever relays... I do think it can be done.
Anyone???
chuck
60
0
6
Not sure how you'd do it with simple electronics, the gears are controlled through the ECU. What I would rather have is the 5 speed tranny!
68,397
Chuck, the theory is you can control the shift solenoids with relays while tricking the computer into thinking it's still in control....
Just a idea though.
5spd would give you closer ratios, def better for power management but also more parts to break, and a higher cost to produce.
I think you could probably trick the ECU pretty easy if you knew to comma protocols. Somehow I doubt power commander or the like will be adding that function anytime soon.
Cloud 9 Rider
Cloud 9 Rider
21
Kansas City, MO
I'm thinking 5 gears would be perfect, leave these 3 where they are and just add 1 low gear for crawling and one high gear for cruising. But I would like it semi-automatic so I can choose paddle shift it auto depending on my mood.
Totally agree, I was playing devils advocate as to why Honda might not have gone that route with the P4
clynwoodg
clynwoodg
10
19
The 5-speed DCT transmission would be great on the pioneer. Just like cloud 9 said 1 low gear, 3 right where they are and an OD for cruising.
