P1000 Pioneer 1000 floor and firewall protection
500
500
589
932
I will also implement some form of this.
You can def tell these machines are heavier than most other side by sides. Weight coming down with stick/log sticking up would push it right through floor board. I came down on a boulder Saturday and the weight of the P1K5 bent the lateral frame rail on the driver's side about where the center of the door is. I was a tad surprised to see that bend so easily. Getting those belly skids sooner than later now.
Reactions: Lady01 and joeymt33
Madore128
175
291
Ma
Need some rock rails that I fab up!!!!!
Reactions: Lady01 and Stauvo
Stauvo
Stauvo
633
910
Minnesota
Regarding the waffel plate in wheel wel. I still wonder about injecting that black rubber adhesive they use to glue on car windows, sgueegy it with a plaster knife, then glue armor plate to it.
Reactions: Lady01
I painted it so I don't have to look at the shiny screws. It's a little redneck but I live in AL so this acceptable.
9cae1675a4bd65e7b44b7d091fe3cdc4
A patient man would have dabbed some paint only on the screw heads with a paintbrush.
A real patient man would have ordered some black screws from McMaster.
i'll get around to doing that one of these days.
Reactions: Lady01
With all the mud and water that I ride in, that black paint will wear off pretty quickly I'm afraid
Reactions: Lady01
Farmer
Farmer
2,973
17,161
Southern MO
I just found this thread but be careful, that plastic expands and contracts a lot it might pull at your bolts and break the thinner plastic below. The best thing to do is make the holes larger than your Hardware. At least a quarter inch. I think the plastic comes with specific instructions.
Sent from my XT1254 using Tapatalk
Reactions: Lady01
Thanks for the heads up. I know the plastic will get hot from the engine heat and then I will dive off into Creekwater and it could contract.
I do appreciate your input and there may be something there to be careful for. Diving off into Creekwater will be an instant cooldown of that plastic so there does seem to be some merit in your statement.
Also, I have seen my UHMW skid plate grow by about 1/8 of an inch when hot and then shrink back down when ever I washed it off with cold water. I actually measured that difference because I could not get my skid plate to line up until I cooled it back down, then I could bolt it back in place. Yes the difference is that my skid plate is bolted to metal and your concern is the very thin plastic bit this is bolted to.
Thanks
Reactions: Lady01
Farmer
Farmer
2,973
17,161
Southern MO
Thanks
No problem. When I was building those tailgates I went from zero to a hundred and fifty degrees testing and it expanded seven eighths of an inch with quarter inch plastic. Hopefully you should be fine, I don't think you're going to those extremes. Lol!!!
I finally did the other side. It turned out to be just as ugly but it's super strong. There won't be a stick going thru that.
1c37dbc65de4b46c5ce00993d913cf50
33f9b60b370776611751c29626489a44
34de5e101cd5a858d7e4552af9fd9838
513e2e8914a42136d070d56618e57b4b
Reactions: Lady01
While doing this I thought about something else, is there a fabric or something more pliable like a fabric or chain mail that can be applied with glue?
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Fiberglass over the top of it and coat it with bed liner material you could put long steel rivets in with washers on the back side
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Maybe we need some Kevlar material?
kevlar blend and resin could work ........ glue the pad to the surface cut to shape and then resin while its on and to make a mold put a wax paper behind it so you could pull it off after the resin hardens
Reactions: Lady01
185,101
You may try forming one piece out of 1/8" thick aluminum for each side.. Use spray on bed liner as a finish and secure it with1/4" x 3/4" long carriage bolts using nylock nuts.
Just saw this thread, never saw that suggestion and that's what I ended up doing, thought it was an original idea I had.
Reactions: Lady01
