P1000 Pioneer 1000 winch and mount questions
I also purchased the same items as you and I did not get a dash switch. I only got the handheld remote.
T
Tinnocker1976
7
Canada
So did any one add the dash switch for the winch? If so did you order from warn and was there a place to pug it in the wiring that came with the honda winch mount?
342639efbfb37bc61375012f89843c7f
Maybe later this evening when I get off work I'll be able to spend a little more time getting you more information about it
The above picture doesn't show the winch switch very clearly. I'll try again
E910ae9761978e666f29441cfef17506
Reactions: sharp
T
Tinnocker1976
7
Canada
So did you buy the winch from honda? and use a switch from some on else? That is a nice set up. If you got the winch from honda did it come with the plug for the switch? Or can i get a wiring harness from warn and a new switch. Thanks alot for helping me with this issue.
I did buy my went from Honda. It's a rebranded warn.
I bought these two switches on Amazon.
8a7de7583a6602dec806ad61546f369f
7512137fcc92843ba301b545b2661b08
The in and out switch receives its power through the winch power button. The in and out switch connects to the solenoid that comes with the winch.
I used a power button to isolate the in and out switch so a child won't accidentally activate the winch and damage the fair lead.
There are wiring instructions that come with the switches
Reactions: dotman1
